Front Receiver Hitch
randini
salt lake/utah
Ok, so I have searched and cant find many pict (or not what I want) of a front receiver hitch. There are times when I think this would be handy. I have seen pintle mounted, not what I am thinking. There was a custom fab, is it possible to mount a stock receiver up front? Oh I do have a wintch.. Any Pictures of someones work?
wreckerman893
Possum Connoisseur
15,618
2,014
Should be easy to fab....just drop down off the frame to what ever height you need.
Might be a little more difficult with a winch truck.
Since I am assuming you are not going to be pulling a trailer down the road in reverse you could even make one that would pin into the shackle mounts.
1,172
I like that idea!:roll:
KsM715
142
St George Ks
I saw that thread last night, I believe his is bolted through the front bumper.
There is a reference to a PS article from 1972 in one of the threads but I searched with google for about 2 hours trying to find it but couldnt.
treeguy
Fort One Bay - Cape Cod, MA
Similar to my rear set up, very minimal alteration to the vehicle. For the front all you have to do is add a front shackle mount to the under side of your bumper. This creates four points of attachment for regidity. I am working on building both front and rear set ups for sale here.
KsM715
142
St George Ks
Have you posted those pics on here before? If so whats the name of the thread. I want to know why I couldnt find it using the search, Im usually pretty sucessful (sp?)
jesusgatos
on the road - in CA right now
For something that you'd just be using to move things around a yard or whatever, think you could probably get away with just boxing-in the center-section of the front bumper and sinking a 2" receiver right into that. Would be low-profile, wouldn't get in the way of the winch, and would always be there when you need it.
Got a HMMWV pintle hitch that am planning on mounting on the front of mah deuce, but might adapt that to a 2" receiver, doing something similar to what I've described above.
DUG
Senior Chief/Moderator
73
Mesquite, NV
You might be ASSuMEing too much. :)
LOL
emr
24
landing , new jersey
Actually i have a front and rear on my f350 and at times at my shop actually have a trailer in front and on back and move em around easily ,also one can put a trailer with a front hitch in alot more places than a rear, that is a fact and have been doin it for alot of years... good luck , do it it works well, with my Job trailers where i live it is hilly and the job lots are tight, its been a God send many times over...
treeguy
That was my whole reason for making the front receiver, just juggling trailers around in my yard. It is soooo much easier being attached in the front, you can not only see better, but you can turn tighter and put trailers where you want.
KsM715
142
St George Ks
How do you put the link in your reply? I have not been able to figure that out.
When searching for a thread, once I find it, I go up to the browser address bar and just highlight and copy the whole thing. Then when I get back to the thread Im in all you have to do is paste the link. Simple copy and paste. SS automatically puts thread name into the address link.
Beerslayer
55
Tualatin, Oregon
Here's what I did. Posted full build photos on a thread somewhere here. It bolts to the frame with two existing holes per side plus one drilled hole.
I wanted it for moving trailers around the yard, needed to be tucked up out of the way, and I wanted to be able to haul a small dirt bike in a hitch carrier.
