treeguy
- 3
- 0
- Fort One Bay - Cape Cod, MA
Nice!
OK question, do you think you could put a mount for one of these? That would be theSimilar to my rear set up, very minimal alteration to the vehicle. For the front all you have to do is add a front shackle mount to the under side of your bumper. This creates four points of attachment for regidity. I am working on building both front and rear set ups for sale here.
I added a winch to my Deuce so throwing the shackles on is no biggie.Well I'd start by mounting your shackle mounts under the bumper. You are going to need a spacer plate to fit where the rear two bolts go. You can use 1/4" x 5/8" diameter washers, but I made plates. If I can borrow a shackle mount from a friend maybe I can make up some plates just for this. You will also need longer bolts for this set up. Check my list in http://www.steelsoldiers.com/deuce/64899-complete-deuce-winch-mounting-bolt-list.html for the size you'll need. The two for the very front ears can be cut flush at the nuts because the extra thread will get in the way of screwing in a regular shackle.
Here's what I did. Posted full build photos on a thread somewhere here. It bolts to the frame with two existing holes per side plus one drilled hole.
I wanted it for moving trailers around the yard, needed to be tucked up out of the way, and I wanted to be able to haul a small dirt bike in a hitch carrier.
