Rifleman
- 1
- 0
- HOT Arizona
Today was a bright sunny day here in Arizona so i took a cold war vet for a ride in my M925. He use to drive 813's in Germany back in the 70's so he wanted to see how different the M925 was to what he drove.
Before we left i did a PM check on the tires,oil and trans fluid. We drove about 45 miles north of the city so we could do a little off roading. We spent about 2 hours off roading and then headed back into town. On the way back home we stopped and filled the tank and while at the station i did a walk around checking for fluid leaks and i wanted to check the tires to make sure there was no damage from the trails we took, everything looked fine. We hopped back onto the freeway heading south, we had about 40 miles to go to get home.
About 5 miles from our off ramp i had a right front steering tire blow out at 55 MPH, i was in the right lane but i have to tell you it took all of my strength to control the truck. As soon as the tire blew it was like someone had put a 1000 pound weight on the steering wheel pulling the truck into a HARD right turn.
The first thing i did was grip the steering wheel in a death grip, then i took my foot off the gas peddle, never once touching the brakes, i then released just a little of my death grip on the steering wheel, this allowed the truck to steer itself to the right, over to the shoulder of the freeway and coast to a stop.
Once i got the truck safely stopped we got out to inspect the damage. The first thing i noticed was a gouge in the pavement caused by the rim leading from what was left of my tire all the way back to the point where the tire had blown. The blow out was so server the tire bead had come completely off the rim both inter and outer, along with that the valve stem had been sheared off too.
After taking a few minutes to thank a higher power that we made it through this without a scratch we got about the job of changing the tire. Now if you have never done this job before it is best to learn how in your own driveway, learning how to do this on the side of a busy freeway during rush hour traffic is the wrong place to learn.
One very important point i would like to make, there was no warning signs at all that the tire was about to blow, one minute everything was fine, we were cruising along at 55 MPH, the next it just blew and we got to experience 30 seconds of shear terror.
All in all i do have to say it was a good day, the lord smiled on us, no damage was done to my truck other then needing a new tire, but i do have to report that my seat cushion is nowhere to be found, i think that has something to do with the pucker factor being so high during the blow out Updated on 9/25/13 with photos of the tire. Please take note that there is only damage on one side of the tire, the side that faced out. Also note the chunks of tread that are missing on the same side of the tire that failed.
