rlwm211
- 19
- 38
- Guilford, NY
crooked steering wheel
You can adjust the steering wheel center on the short drag link between the steering gear and the knuckle to correct the center of the steering wheel. To be honest, the front end shop should have fixed that when they did the alignment. It is part of the procedure to be honest.
RL
I JUST had the same issue. It ended up being upper and lower ball joints on the PS and the inside tie rod off the pitman arm were bad. Did the replacements myself and paid for an alignment. Drives like a DREAM now. Steering wheel is a little off but the steering wheel wander is gone too.
RL
