CPDOG
- 23
- 8
- SEABECK WASHINGTON
hi
I have a m923a2 and have replaced the fuel filter on the engine then I noticed a larger one just behind the drivers wheel that the tech manual says only applies to a m923a1? in the tech manual it states that to change this filter to open the drain and isolate the valve from the tank....did this but the valve in question has had its valve stem removed and capped (fuel free flows thru valve body). the filter still functions as advertised. so 2 questions 1. has anyone seen this set up? 2. if it is a hybrid of some sort, does anyone have the correct filter part # for the a1 style filter?
thank you all for the assistance
