Fuel Tank Straps
Jersey4x4
Absecon, NJ
Does anyone know where to get replacement fuel tank straps for the primary and secondary fuel tanks? Prefer new but used good is fine also.
m816
Chatham, NJ
I have been making my own from sheet metal. Just have your local shear some sheet metal at the width and make it plenty long. Use an angle grinder with a cutoff wheel to make a slot inthe end that you have folded about two inches back from the end. I then cut the hexhead off a 5/26 x 2 1/2 bolt and weld a tee tothe top . You now have the start point no need to weld the end closed since the bolt will not pull through the slo. I put the open end on the inside. measure it up to the original or wrap it around the tank to be strapped and you hav ethe overall length. Repeat step one for the other end and you will have the same strap that was made at the factory. for a fraction of the cost of a new one.
Jersey4x4
Absecon, NJ
How did you attach the nylon webbing to the inside of the strap? The OE strap is rivited with spun rivets
Beerslayer
55
Tualatin, Oregon
I like m816's idea of how to make the straps. I don't know how he fastened them but I can tell you what would work well. Copper harness rivets. You wouldn't even need to use the copper washer, and they are soft enough that they wouldn't wear through the tank if they rubbed. Just drill a hole through the strap and the steel, push the rivet through, cut it off about 3/16" or so, put the rivet base on an anvil and smack it with a hammer.
You can buy them here, here, and here.
219
new smyrns beach fl
tank straps
i also have made fuel tank straps , made the same way but i used 1 1/2 inch galvanized metal banding straps, courtesy gov liq. needed some banding strapping material bot had to buy about 35 large rolls .
timntrucks
Ponchatoula LA
i have some used ones that i took off last week. going to clean them up and paint them never know when you might need a strap
