About 4 years ago I had my pump rebuilt (expansive) I ssems that the seal around the throttle linkage was leaking, letting fuel run all over the block and making a huge mess.This only happened in extreme cold weather conditions, and I found that by placing a drop light under the hood at night it would provide enough warmth to keep the seal from contracting. Now It's happening again, even under warm to hot conditions. Is it worth it to attempt another rebuild, or is there a better after market pump that won't suffer this same problem. I'd also be interested to hear from others that have had this same issue.
