Fule leaks from Injector Pump om my M1008 CUCV (again)
BiggEric
About 4 years ago I had my pump rebuilt (expansive) :roll: I ssems that the seal around the throttle linkage was leaking, letting fuel run all over the block and making a huge mess.This only happened in extreme cold weather conditions, and I found that by placing a drop light under the hood at night it would provide enough warmth to keep the seal from contracting. Now It's happening again, even under warm to hot conditions. Is it worth it to attempt another rebuild, or is there a better after market pump that won't suffer this same problem. I'd also be interested to hear from others that have had this same issue.
CCATLETT1984
Saint Clair Shores, MI
I would also have a chat with the shop that did your rebuild, should last much longer than a few years. Maybe they'll do it for a much reduced rate., It's worth asking about. If they give you guff then ask around here, odds are that someone on the forum has a spare rebuilt IP sitting on a shelf.
ALSO PLEASE PUT YOUR LOCATION IN YOUR SIG, ITS IN YOUR PROFILE. ITS ONE OF THE FEW RULES, BUT YOUR POSTS WILL BE REMOVED IF YOU DON,T.
BiggEric
Sorry, No Pic's as of now. I don't have a digital camera (Yet, perhaps the wfie will let me spend some of my money :) I added my location to my SIG, sorry about that. I've got a friend with a camera, and I'll see what I can do next time I see him, I've got to figure how to post them too, I'm a bit new at this.
muddobber40
la cygne, ks
No need in having it rebuilt. Its about a 45 min. Job and you don't really need any special tools. Just need to loacte new bushings and the o-rings. If you want to try and tackle it PM me and I can send you some details on how to do it.
