OttoVonMog
- 0
- 0
- Windham, NY
Check it out...
http://www.youtube.com/watch?v=_kU_GevysZ4
The tires do need to go... but I think that will have to wait- until I get a few more goodies for the truck... Air Lockers are on the list as are super singles- 365/85R20 size tires I'm thinking. I would love to stick a CTIS system on the truck as well. That way I could have positive traction to both the front and rear axles, left and right sides and maximize my grip by changing the foot print of the tires. It would be the best solution I think.If you want more traction. It's time for new tires michlien or goodyears. Or some will say chains or air down the tires some. Someone has also took a tread regroover and cut grooves in the ndt tread pattern. Just my two cents. It looks like you are having fun anyway. You can send some down to Pa if you want.
Chains have their uses, but if you want to really maximize the truck's traction ARB lockers are the key. Then you put the chains on and then you have a tank.I was having similar lack of traction on mine plowing the drive the other day, luckily I had chains on the front axle otherwise I wouldn't have made it up the hill! Just for fun I tried the moderately steep hill without the front axle locked, I might as well have been in neutral.
Why is it that people/truckers only chain up on one axle. I mean I have watched shows like Highway from ****, and the truckers only chain up one axle, so their other axle just sits there spinning. I thought the plan or idea was to effectively chain up all you active or semiactive driving axles in order to increase traction.one set of chains would help a lot. You would be amazed how much difference it makes. Ive never tried them yet on ours since we havent had much snow in the last couple years. But on 2 wheel drive trucks (C8500's and F750's) they are awesome.
You need a USMC M923 or M925 truck with Detriot lockers.
ARB's require air which can be a problem if the lines freeze, and they will freeze. KISS
Forget attempting adding CTIS to your truck and just purchase an A2 series vehicle.
The truck with 14.00x20 or 395X20 tires will out pull the NDCC or NDT tires. If you don't want either of these tires, then look at 11.00x20 G177 tires.
That looks cool.Looks like fun!
Grooving does help both in snow and rain, but chains are a must in packed snow with the ND's. Here is a picture of my grooves.....
