Functions of the eess box?
Skrilex
Banned
356
Portland Oregon
What does this troublesome eess box actually do? And moreover, how do we bypass it? It seems hardly worth messing with. I don’t need fancy glow plus timers and whatnot. A simple momentary button to heat them is fine by me and seems more reliable from what I’m reading.
Hummermark
31
London uk
Hi I was thinking the same thing did a search if any one had put a solenoid in the EEss box with a sprung switch through the side but could not find anything.
i did it with a couple of the older boxes that had the solenoids in and they have been fault lesss for ten years now.
ikoinu
21
Los Angeles, CA
Just did it. Deuce & a half momentary switch, 24v relay, extra set of factory glow plug cables (didn't want to cut into the existing ones), wiring and ring terminals. Works like a charm.
Will post thread with pics, part numbers and walk through soon.
Skrilex
Banned
356
Portland Oregon
So, to ask the question a different way, can we toss the box out the window if we provide another means of heating plugs? No other functions going on?
Skrilex
Banned
356
Portland Oregon
Another bonus with this mod is that we can hide the glow button which will essentially add security to the truck, unless it's been driven and still warm lol. Okay scratch that.
Dock Rocker
71
Jackson ms
If you do this mod you had better hide the button. Not for security per se but to keep the glowplugs alive.
If you have someone come along and fat fingers it for 20 or 30 seconds then they have smoked your plugs and you get to start changing them again.
People aren’t really smart and kids don’t think know better. It’s a good mod, I did it on a cucv, but you have to be on the lookout for the low IQ operators.
DCIV
Morristown, TN
I would love a plug and play kit for this. If this box does cause as many issues as I've read then I would rather replace it with a better options.
Hummermark
31
London uk
The switch I fitted to the older box was to the side facing the reinforcement ribbing of the body so had to know where it was to reach it under the dash also when I left it had a battery terminal isolator.
rather then do away with the eess I was thinking if you can do away with the circuit bord that controls the glow plugs with a solenoid inside the eess box with a protruding switch through the box and leave the rest inside the eess as is.
Dock Rocker
71
Jackson ms
The new boxes really don’t have issues. The older boxes do have a pretty high failure rate. Many of those failures can be traced back to poor grounding. You can dramatically prolong the life of the older prestolite boxes by adding a grounding harness.
Action
1,551
East Tennessee
If you do a hodden momentsry switch, you could put in a row of toggle switches that must be flipped a certain way to allow power to the momentary switch. Like in mad max fury road.
ikoinu
21
Los Angeles, CA
I didn't bother hiding the button. The factory control box is much more competent at burning out the plugs than a random button pusher in my mind. Have to wonder how they ever designed something like that. It's a military vehicle, common sense dictates you design a failsafe into it.
Mine failed and runs 24 volts into the plugs 100% of the time.
Action
1,551
East Tennessee
I see quite a few folks stating their plugs get 24v all the time.
Is this checked just after starting or after driving for a while? Some of the boxes provide afterglow, which could show 24v at the leads after the engine is started. right?
ken
24
Houston Texas
I have seen one with a M37 foot starter He just pushes it with the palm of his hand and counts to ten. Simple and no extra stuff to fail. It looks like a knob and it pretty tough for a kid to push and hold.
snowtrac nome
137
western alaska
So y’all think if I leave the box out completely that it will affect any other systems?
yes it will, you also have a starter lock out function in it and a starter relay natural start function is wired in to it. you can crank the engine off sand t terminal on the steice plug but there is no natural start function it would also start in gear.
