GAA Grease
SixBuy
Dallas/Texas
Got the Lubrication Order off RDM's CD today (Thanks RDM - your million is in the mail...). Lots of places to use GAA but no GAA! Does anyone know of an acceptable substitute for GAA? Most grease is formulated with Molybdium or Lithium and the two can't be mixed. So any ideas as to what GAA is? Or anybody got a copy of MIL-G-10924!
SixBuy
Dallas/Texas
Seems I've answered my own question - Did a Google search on 'MIL-G-10924' and determined it was Lithium based and basically a generic NLGI-2 grease. Which fits with what MVTrucker said about 'blue' grease. WWW.lubeandtune.com.au/html/lubekey.htm has a chart "Key To Lubricants which addresses some of this which also points MIL-L-2105 gear lube to GL-4 and MIL-L-2105B/C/D/E to GL-5 ! Seems to me like everyone say use GL-1 only. Who's right?
Elwenil
40
Covington, VA
We were discussing this exact point on the M715Zone today. I found the same page you did, lol. We were disussing what to use in the closed knuckles of out front Dana 60s. Appearantly, a lot of typical wheel bearing grease conforms to the listed NGLI-2 (grade 2) and Chrysler MS-3701. Time to go and start reading grease cans at the parts store. I myself happen to have several cases of Mopar Multimileage Grease (P/N 2525035) that will work.
Here's a clickable link to the page:
http://www.lubeandtune.com.au/html/lubekey.htm
mhb285
Paso Robles, Calif.
I just did my whole truck with Valvoline Moly Fortified Durablend Synthetic - NLGI #2 GC-LB Lithium grease...And no problems as of yet.. Hope this is OK
I saw in the tips section that if your steering box is leaking to use grease in it as a alternative to fixing the hard to replace seal...
Any thoughts on on the steering box solution?
Mike Bogner
sailor2000
Houston Texas
Have been searching here and on the web for a specification for GAA that will tell me what it is. Found out more than I thought I wanted to know about greases, including many dire warnings from grease manufacturers not to mix grease types, but nowhere can I find what base and composition GAA is. Is it a lithium type as was said above and if so, which lithium????? A grease compatibility chart http://www.mindconnection.com/library/handyman/greasecompat.htm that tells what greases you can mix shows several types of lithium greases. Also, some 'grease' posts here seem to say that it is not a lithium base grease.... Anyone have the official info?
BTW - I did find two helpful general info sites on grease certifications http://www.nlgi.com/certification.htm and http://www.usace.army.mil/publications/eng-manuals/em1110-2-1424/c-5.pdf which explain the NLGI "number" and the ASTM classification, neither of which have anything to do with what the grease is made of or it's compatibility with another grease.
acetomatoco
Will be a lot better than the thousands of M880s which were shipped with no oil in the steering boxes..!!
1,808
$55 for a 35# (5 gallon) pail seems high. Papercu may have some left. I've been getting my GAA from him. I have 2 1/2 35# pails left. Should be enough for about 10 or 15 years.
houdel
9
Chase, MI
If you spend a lot of time hunting around, you CAN find GL-1. But don't bother. A GL-5 gear oil meeting the MT-1 spec is an acceptable substitute and provide better lubrication properties. I use Valvoline 85W-140 gear oil, GL-5 and meets MT-1. I get it at Wally World, but any GL-5 which STATES ON THE LABEL that it meets MT-1 will work.
The issue has to do with certain advanced (post GL-1 gear oils) which may damage the type of synchronizers used in the Deuce tranny. This issue is only applicable to the tranny and transfer case which are synchronized, I have not heard of any incompatibilities with modern gear oils in the axles.BUT, I'd pick only one GO and use it everywhere, rather than try and remember which GO goes where. However, the jury is still out regarding synthetic gear oils. Some SS members swear by synthetics, but just as many swear AT synthetics. This may be brand related, but until convincing evidence appears to change my mind, I'll stick with petroleum based GO.
For more info on the synchronizer issue, see:
http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=2506
sailor2000
Houston Texas
doghead said:
sailor2000 said:
BUT.. what IS IT???????????????????????????????????????????????????
GAA/ Grease Automotive and artillery
It is a proprietary secret!
http://kauai.hawaii.edu/msds/files/cjj/cjjfy.html
Does anyone have the full text of the mil spec for GAA? It will spell out exactly what it is made of... Then I can (hopefully) get the major grease manufacturers to say what is equal and what is or is not compatible....
1,177
Sailor, i fixed the link the night i posted it, and it works for me. Anyway, here is what the link has:
SUMMIT LUBRICANTS INC -- MIL-C-10924F, SL-065
MSDS Safety Information
FSC: 9150
NIIN: 01-197-7693
MSDS Date: 02/25/1999
MSDS Num: CJJFY
Product ID: MIL-C-10924F, SL-065
MFN: 02
Responsible Party
Cage: 0R0E6
Name: SUMMIT LUBRICANTS INC
Address: 4080 PEARL STREET
Box: 966
City: BATAVIA NY 14021
Info Phone Number: 716-344-4301/716-685-1576
Emergency Phone Number: 716-344-4301
Item Description Information
Item Manager: S9G
Item Name: GREASE,AUTOMOTIVE AND ARTILLERY
Specification Number: MIL-G-10924F
Type/Grade/Class: MILITARY SYMBOL GAA
Unit of Issue: CA
Quantitative Expression: 00000000014OZ
UI Container Qty: 1
Type of Container: CARTRIDGE
Ingredients
Name: *** PROPRIETARY ***
Health Hazards Data
LD50 LC50 Mixture: NONE SPECIFIED BY MANUFACTURER.
Skin: YES
Effects of Exposure: MILD, TRANSIENT SKIN AND EYE IRRITATION.
Explanation Of Carcinogenicity: NONE SPECIFIED BY MANUFACTURER.
Signs And Symptions Of Overexposure: MILD, TRANSIENT SKIN AND EYE IRRITATION.
Medical Cond Aggravated By Exposure: NONE SPECIFIED BY MANUFACTURER.
First Aid: INGESTED-DO NOT INDUCE VOMITING! GET MEDICAL ATTENTION. SKIN-FLUSH
WITH SOAP & WATER. REMOVE & LAUNDER CONTAMINATED CLOTHES. EYES-FLUSH
WITH PLENTY OF WATER FOR AT LEAST 15 MINUTES. GET MEDICAL ATTENT ION.
INHALED-NOT APPLICABLE.
Handling and Disposal
Spill Release Procedures: ABSORB WITH SAND OR INERT MATERIAL. SWEEP OR SCOOP UP
AND REMOVE.
Neutralizing Agent: NONE SPECIFIED BY MANUFACTURER.
Waste Disposal Methods: INCINERATE.
Handling And Storage Precautions: KEEEP AWAY FROM SPARKS AND OPEN FLAMES. DO
NOT GET IN EYES OR ON CLOTHING. WASH THOROUGHLY AFTER HANDLING.
Other Precautions: NO SPECIAL CONDITIONS.
Fire and Explosion Hazard Information
Flash Point Method: COC
Flash Point: =243.3C, 470.F
Autoignition Temp: =265.6C, 510.F
Extinguishing Media: WATER FOG, CARBON DIOXIDE (CO2), DRY CHEMICAL, EARTH OR
SAND.
Fire Fighting Procedures: WATER MAY CAUSE FROTHING.
Unusual Fire/Explosion Hazard: NONE SPECIFIED BY MANUFACTURER.
Control Measures
Ventilation: USE WITH ADEQUATE VENTILATION.
Protective Gloves: NEOPRENE, BUTYL RUBBER, POLYETHYLENE.
Eye Protection: FACE SHIELD.
Other Protective Equipment: NONE SPECIFIED BY MANUFACTURER.
Work Hygienic Practices: WASH THOROUGHLY AFTER HANDLING, DO NOT GET IN EYES OR
ON CLOTHING. KEEP AWAY FROM SPARKS, AND OPEN FLAMES.
Supplemental Safety and Health: NONE SPECIFIED BY MANUFACTURER.
Physical/Chemical Properties
HCC: V6
Boiling Point: =371.1C, 700.F
Melt/Freeze Pt: =260.C, 500.F
Vapor Pres: <0.001 @ 20C
Spec Gravity: 0.88 @ 16C
Solubility in Water: NIL
Appearance and Odor: AMBER GREASE-BLAND
Percent Volatiles by Volume: 0
Reactivity Data
Stability Indicator: YES
Stability Condition To Avoid: OPEN FLAMES.
Materials To Avoid: STRONG OXIDIZERS.
Hazardous Decomposition Products: CARBON MONOXIDE (CO) OR CARBON DIOXIDE (CO2)
IF INCOMPLETE COMBUSTION.
Hazardous Polymerization Indicator: NO
Conditions To Avoid Polymerization: NONE SPECIFIED BY MANUFACTURER.
Toxicological Information
Toxicological Information: NONE SPECIFIED BY MANUFACTURER.
Ecological Information
Ecological: NONE SPECIFIED BY MANUFACTURER.
MSDS Transport Information
Transport Information: NOT RESTRICTED.
Regulatory Information
Sara Title III Information: NONE SPECIFIED BY MANUFACTURER.
Federal Regulatory Information: NONE SPECIFIED BY MANUFACTURER.
State Regulatory Information: NONE SPECIFIED BY MANUFACTURER.
Other Information
Other Information: NONE SPECIFIED BY MANUFACTURER.
Transportation Information
Responsible Party Cage: 0R0E6
Trans ID NO: 146515
MSDS Prepared Date: 02/25/1999
Review Date: 07/23/1999
MFN: 2
Net Unit Weight: 14 OZ
Multiple KIT Number: 0
Unit Of Issue: CA
Container QTY: 1
Type Of Container: CARTRIDGE
Detail DOT Information
DOT PSN Code: ZZZ
DOT Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
Detail IMO Information
IMO PSN Code: ZZZ
IMO Proper Shipping Name: NOT REGULATED FOR THIS MODE OF TRANSPORTATION
Detail IATA Information
IATA PSN Code: ZZZ
IATA Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
Detail AFI Information
AFI PSN Code: ZZZ
AFI Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
HAZCOM Label
Cage: 0R0E6
Company Name: SUMMIT LUBRICANTS INC
Street: 4080 PEARL STREET
PO Box: 966
City: BATAVIA NY
Zipcode: 14020
Health Emergency Phone: 716-344-4301
Label Required IND: Y
Date Of Label Review: 07/23/1999
Status Code: A
Year Procured: 1999
Origination Code: F
Eye Protection IND: YES
Skin Protection IND: YES
Signal Word: CAUTION
Respiratory Protection IND: NO
Health Hazard: None
Contact Hazard: Slight
Fire Hazard: Slight
Reactivity Hazard: None
Hazard And Precautions: TARGET ORGANS: SKIN, EYES. MILD, TRANSIENT SKIN AND EYE
IRRITATION.
Disclaimer (provided with this information by the compiling agencies): This
information is formulated for use by elements of the Department of Defense.
The United States of America in no manner whatsoever expressly or implied
warrants, states, or intends said information to have any application, use or
viability by or to any person or persons outside the Department of Defense
nor any person or persons contracting with any instrumentality of the United
States of America and disclaims all liability for such use. Any person
utilizing this instruction who is not a military or civilian employee of the
United States of America should seek competent professional advice to verify
and assume responsibility for the suitability of this information to their
particular situation regardless of similarity to a corresponding Department
of Defense or other government situation.
sprucemt
14
Warrensburg NY
I spoke with Len Wise at Dumont Specialty. He re-packs and is a distributor for military grease. The BASE grease for GAA is "#2 lithium complex grease". #2 lithium complex grease off a store shelf is not GAA, UNLESS the container states that it meets specs for MIL-C-10924. There are a multitude of addtitives added to the BASE grease to make it GAA. It is NOT a generic grease.
Current prices at Dumont are $10.60 per pound. Cartriges are $19.84 ea, 10 to a case, 40 to a master case. Around $372.00 for a 5 gallon pail.
I sell GAA on my website for $11.00 per 6.5 pound can and $55.00 per 35 pound pail plus $7.00 out of box charge on the pail. Limited amounts of pails are left.
Manufacturers include Summit, Anderol/Royco and Sowesco - olathe.
otrman
Try looking here.
http://assist.daps.dla.mil/quicksearch/quicksearch_query.cfm
This has the latest spec and the QPL. This is also a really good source for other mil specs.
