gages
deess
crosby,tx
Does anyone have pictures of their pyro and psi (turbo) gages installed? Where you tied them in to be exact and mounted them in the cab. thanks in advance, Shane
deess
crosby,tx
:oops:sorry again just realized or figured out there are attatchments on the forum page, i guess that is where you all posted the pics
FreightTrain
Banned
2,730
13
Gadsden,Al
Pull your turbo and drill the manifold for the probes.I used 2 gauges and probes(Stewart Warner gauges($100 for the pair) and 2 K-Type probe kits made by Autometer(Around $120).No power required to run them.The full autometer gauge kit requires 12V power since the gauge has a Amplifier build into it.The Stewarts didn't.The exhaust system is built into Front and rear banks.There is a divider in the manifold and in the turbine housing.This way I can keep an eye on both banks.If one starts showing higher or lower numbers then I know I have a problem and only have to figure out which of the 3 holes is the problem instead of all 6 holes.......Now I wish I could afford a 6 gauge setup to keep an eye on every hole.....but that is a little overkill.The dash would look like a Peterbilt if I installed all the gauges I want on it.3 diff temps,air pressure,Boost pressure,Intake temp,6 EGTs,Oil temp,Oil pressure,Volt,Amp,Trans temp,Transfer temp,Water temp,Fuel pressure,Fuel level......shall I continue?
