Gas or Diesel?
russ81
cambridge, ohio
I have a `59 Reo that I just finished bobing. The first question I have is should I keep the OA 331 gas engine, or swap out for a diesel? I don't know anything about this particular engine, and I don't know if it is worth spending the time and money on. Second question is if I do keep this old gasser, how available are the parts, and will I spend a fortune on rebuilding it if I have to?
Any help you guys could give me would be greatly appreciated. Also, I would love to hear every ones opinion of this particular engine, and how it would perform in a bobed duce with 16 x 20 tires.........new wheels will arrive next week!!!!!!!!
maddawg308
745
Front Royal, VA
My opinion - drop in a diesel from an A2, and sell off the gas engine to someone restoring a gasser truck. I think you'll like the performance upgrade.
54reo
49
Chester IL
...another gasser gone...
Although, it is your truck and it looks like you did a good job. As stated above, sell the gasser to a collector.
beaubeau
Salisbury,N.H. 03268
Russ81, There are a number of Diesels U can put in that truck. U can put in a Cummins, 5.9 would fit nicely, U can put in an International DT360, which is a nice running engine and available in large #s." Schoolbus Motor",How about a" ScreamingJimmy", Detroit 6-71,Or even a Deutz 6 Cyl Turbo !!?? Also remember, it may cost a little more for Diesel, but U go further with a gallon of Diesel than a Gallon of gas. Good Luck, Phil
