Geared hub drain plug removal advice
MattNC
271
Raleigh, NC
once you get it out you can replace with a square-headed plug from the hardware store. I am blanking on the thread size and pitch but it makes it much easier to do service in the future instead of a recessed allen style. I have an example of what I am talking about below.
Mogman
10,599
Papalote, TX
You want to have the OEM magnetic plugs, that way you can see any bearing failures coming your way and the magnet extends the bearing life by capturing particles that would normally circulate causing more damage.
There is NOTHING wrong with the original plugs, ALL failures are due to piss poor practices, not cleaning the plug correctly before trying to remove them, using the wrong tool to begin with and over tightening are the major factors.
nairb
115
33
Liberty Hill, TX
Success with the Ridgid set. I think the vertical splines are the key to this set, it grabs really well. It also helps that it doesn't break off when extracting. I did try some Hanson multi spline extractors first but they didn't grab deep enough and ended up just widening the hole in the soft metal.
I was able to fish out the magnet from the old plug but I'm worried about other metal shavings left behind in there so I'm going to wait for magnetic plugs to come in before I put it back together.
springer1981
1,184
Maine
This is truly my favorite extractor set. I have used them for many years on so many different stuck, stripped, frozen and broken bolts over the years. The key is to make sure you slide the nut on all the way to the stuck bolt. Congrats on your extraction.
