Gen 1 dumb question #1
82ABNMP
53
Winston Salem NC
I bought the O'Reily Part Number: 01-0136
1975 Caddy Commercial - 100amp alternator for the drivers side of my M1009 but where do I hook up the ground wire? There is no ground post on the rear of the case like on the original.
David
doghead
4 Star General /Moderator
1,193
NY
That specific alternator is grounded through it's mounting bolts. That is why it only works on the drivers side in a CUCV. No need for the ground wire with it.
Never use that alternator on the other side!
82ABNMP
53
Winston Salem NC
Alt 1
Hey John, I tried to call yesterday but didn't get you. I was trying to work this out on my own without bothering you! :-DI did see that bolt on the back of the Gen and thought it would work. The Gen that was on the truck I took off because the pulley was making a lot of noise but it was the original Alt and was rebuilt a year ago by the PO. I ended up re-installing the original Gen 1 and it sounded fine. :cookoo:So now the other one is a back up for the driver’s side.
If I do install the new Gen in the future what should I do with the small black and white ground wire? Find another ground?
David
