Gen 1 not working
Horsis
az
Sorry if you guys addressed this a 1000 times
i am having problem trouble shooting this because i can not unplug the the connector on Gen 1
here is where I am (and thank you in advance for any help )
Gen 1 light stays on
battery 1 front is reading 12.4v when running which is same i get on red wire on gen 1 ( is this enough to say gen 1 no good? )
total voltage when running is 26
As I said can not remove connector on gen 1 would rather cut and splice wires if nec. Than try and find another plug if breaks
once again TIA from an old Jarhead
Warthog
244
OKC, OK
Welcome to the site.
Please let us know which truck you are working on. It keeps the guessing to a minimum. ;-)
The alternator is not working. You are just reading battery voltage.
The two wire plug has a small tab that needs to be moved to remove the plug. You can get replacement plugs at just about any parts store for ~$5.
We have covered the alternators many times and you may find some helpful reading in the CUCV Wiki and the CUCV Helpful Treads sticky
http://www.steelsoldiers.com/content.php?2-CUCV-Wiki
http://www.steelsoldiers.com/showthread.php?123199-CUCV-Helpful-Threads
And also read the Generator Exciter Troubleshooting thread.
http://www.steelsoldiers.com/showthread.php?121589-CUCV-GEN1-and-GEN2-Exciter-troubleshooting
And a word of advice. The F-bomb and all the usual abbreviations are not needed on the website. We attempt to keep this site above all the others.
Warthog
244
OKC, OK
Does your heater fan work? If not replace the very top fuse and see if your alternator starts working
Horsis
az
Thanks found that and to continue with tm i turned on to run and light out
TM 20 say replace gen1
is this test and the fact that do not get 14 volt on large red when run enough to say alt Need R or R ?
Warthog
244
OKC, OK
Pull it off and have a shop test it. Disconnect your batteries first.
Horsis
az
Thanks for the help I will pull gen 1 in morn and look for new one
and take my time and rebuild this one
any pointers where to buy one appreciated
