hrbergeron
- 411
- 63
- Geographical Center of Virginia
Need help. Need to get back running because power is out. The generator was running fine and when I looked outside at the panel I saw 160 volts on each phase. Turned off the output and now it won't put out any voltage. The "LOW FUEL/STOPPED" warning light is on. The fuel is not low and is full. Generator is a DRASH Hanco 20kw.
