Generator MEP 803A problem “over voltage”
Captcday
Florida
Generators. Have a MEP 803A throwing a “OVER VOLTAGE “ light and shutting down . Does anyone have any suggestions on what is broke ? Possibly the voltage regulator? Part # 19580
Light in the Dark
5,513
MA
Can you be more specific on details, like under what conditions it happens.. right after startup? After running a while? Have you performed any testing on items in the set related to this, or referenced the tech manual?
Captcday
Florida
At first it quit right after start up. We cycled the 1/3 phase switch a dozen times or so and it did start. We had it on a load bank at 7kw single phase and it ran for about 5 minutes. Then it quit again. Throwing the Over Voltage again.Do not know what to test. Also do not have a tech manual .
Daybreak
2 Star Admiral
760
Va
Howdy,
Start here in this thread. The 2nd post has quick links to lots of stuff. The third post has links to the manuals.
Light in the Dark
5,513
MA
Yeah get the TMs first and foremost.
TM ending in -10 is an operators manual
TM ending in -24 is the troubleshooting manual
TM ending in -24P is exploded parts diagrams of everything that makes that machine up.
For troubleshooting purposes, almost EVERYTHING you could ever encounter, is covered by the -24. I think you have a corrosion issue, and I think you need to plan on purchasing a good contact cleaner, and taking the roof off the machine to get to the fun stuff.
