genset loadbanks
Waukesha
31
Grand Rapids, MI
I was able to source a Swift E Ultra 20KW load bank used through that online auction site for $500 shipped. Works great. As others have said, there's more cost effective ways to accomplish this task. I have an all gas house, and no space to store an electric stove, and live in an HOA neighborhood. I can't run a 55gal drum full of water, etc. Good luck!
shanekarl
57
Fort Worth, Texas - USA
Thanks for the feedback! I have decided to wait for a 30kw or larger load bank. Hopefully ill run across one for a fair price in the next few months or so.
mrbearski
Purchased a MEP-003a a few weeks and am in the process of getting it going. Also working on building a load bank to be able to fully test it once running. From what I have acquired, I believe that I will be able to test all the way up to 17.4 kw in 500 watt increments all for an investment of about $250, plus whatever my son costs me to fabricate a case for it. Once done, I'll attempt to attach some pics.
Waukesha
31
Grand Rapids, MI
The Swift E is a VERY good load Bank. Smaller, easy to transport. But the A427A is built like a beast. Its not something you can walk away with!.
As it goes, mine was actually damaged in shipping. I picked up the box (yes they shipped it in a cardboard box...) and noticed something was loose inside, and dents on the sides. I sent pictures to the seller and they promptly refunded my money and told me to keep it! I was able to reassemble the contactors and it works great. It's definitely NOT built like a tank. But it works :)
deherenman
27
Texas
Looking at building a load bank versus buying two 5kw shop heaters.
Looking on Depot, it looks like 35 00-4500 and 5500 water heater elements are anywhere from $9 to $13 a piece.
My question is how much? CFM is coming out of the great above the radiator? On the 803a. I rig up a mount and air cool those water heating elements with the amount of cfms that are being blown from the radiator fan alone?
Versus putting them in a 55 gallon drum of water.
Just putting this out there for food for thought
20,814
Looking on woke Depot, it looks like 35 00-4500 and 5500 water heater elements are anywhere from $9 to $13 a piece.
I think dropping in two heating elements into a 55 gallon bucket of water would work well. At least for a little while. The water will heat up and the water will boil off eventually.
Coug
4,841
Olympia/WA
Water heater elements typically only have the element portion in the water, so SAFELY mounting them into something like a 55 gallon barrel or bucket of water is extremely important.
Exposed electrical connections for one, especially if you are mounting them vertically down into the top of the bucket/barrel. Also needing to properly ground the electrode housing and water do make it a little more complicated than just sticking the electrode into water and calling it good.
It might cost more, but using shop heaters or an old dryer is a lot safer.
reset2
102
Myersville MD
Might seem odd but an oven works too. I own and work on rental properties. Had an oven scheduled for delivery and thought time for a load test. Forgot to do an amprobe measurement at the time for actual current draw, but with four stovetop burners and the oven on the 803's gauge showed 75%.
If you zoom in you can see my plug adapters for different configurations of cords.
Sent from my SM-G781U using Tapatalk
2Pbfeet
1,530
Mt. Hamilton, CA
NorthernTool.com has a couple overhead garage heaters on clearance today.
5000w for $76.99 pics show 3/4/5 kw settings
7500w for $65.99 pics show 7.5/5 kw settings
Both of those are a "Keebar" brand, which I've never tried nor heard of before, but the price is cheap.
Great price!
Personally, having looked inside a few of them, I think that these heaters are all made by the same global manufacturer. YMMV. I have one of the 10kW ones. Inside, the circuit boards appeared to be designed for absolute lowest cost, and were all set up for and ready for 3 phase 240V, and just needing to move a couple of wires.
All the best,
2Pbfeet
