Oerthedge21
- 20
- 18
- Northford CT
That's antennaclimber's card. HW is a reseller for them.The new card is from Hillbilly Wizard.
Negative, I don't think that's the correct connector/bundle, but I'm diving into the wiring TM's right now to verify the wire colors.View attachment 740277
You mean this bundle here? Looks the same, except this plug is routed up around the top of the instrument clutser. I unplugged it and turned the key on, and the glow plug system still functioned, which correct me if I'm wrong but shouldn't the glow plugs not be able to cycle with the card unplugged?
Follow the pink/black wire in this photo on the engine side of the firewall. Where does it go? It should go to glow plug relay.
It's looking like someone removed your military-style glow plug card controller and might have installed a civilian-style controller on the engine side of the firewall. This is a common modification when a military GP system is misbehaving and someone doesn't want to troubleshoot the system...Oh man the further I go the worse it gets. I'm not sure how this system functioned at all honestly, looks like I might have to rewire the whole system, or is it savable somehow?
Don't worry about it, I was already under there poking around anywayI stand corrected about the two little boxes.I now know there are supposed to be three and the third is larger. Sorry if this wasted your time.
Well that would explain the mess and MIA gp controller. So that thing down in the head is actually the controller? I thought it was the temp sensor, considering the civilian controller went in the driver's side head (correct me if I'm wrong) and the temp sensor was positioned in the pass side head.Follow the pink/black wire in this photo on the engine side of the firewall. Where does it go? It should go to glow plug relay.
Also, the purple/white wire that is spliced with electrical tape with a red wire at the top right of this photo...the red wire goes around the grommet and thru the firewall to the engine side...Where does it go? It should go to a glow plug controller, as the purple/white wire is the "after glow" signal wire, and normally goes to the military glow plug controller card on the cab side of the firewall.
EDIT: In light of your engine side photos, you have a civilian glow plug controller and your wiring has been modified as such.
