So as I mentioned in another thread, I have a troubled history with auto electrical so I'm treading carefully on everything here. I've replace the farthest front and back battery cable terminals with their original eyelet-style versions since all terminals are pretty banged up. I'm replacing the connector cable in the middle completely since it's a crimped on job and utterly mangled on both ends. Napa has a replacement 4 gauge 24" wire for 8 bucks.
Now for the problem at hand. While looking over things to familiarize myself with GP bypass mod I realized that THIS is definitely not right.
![GPWireSM.jpg GPWireSM.jpg](https://www.steelsoldiers.com/data/attachments/369/369693-8963e5bb735db58ee91e864a42a20a16.jpg)
I'm not sure from the TMs if this is a wire with a fusible link or what's inside that ball of hate. I also need to know what gauge of wire this is so that I can get the right size ring terminal both for the new battery connector and for the terminal connector above the relay. It looks like I may be able to cut that corroded wire right at the nasty part and connect it with that short of a wire.
Help is always appreciated.
