Jimc
- 9
- 18
- Mullica, nj
Yup 7/16x20 is right jerry
Thanks. You didn't need to add "hopefully"if you drill all the way to the bottom of the hole where the copper gasket would be sitting you will separate the electrode from the body. you dont want to do that. just drill in 3/4" of so. enough to get an easy out in there or something then the whole thing will come out together....hopefully.
just thought of one more question. Is the electrode hard material or will it drill easilyhaha, let us know what happens. remember heat is your friend!
They seemed to work fine. I guess if there is an issue it will show up down the road but all looks good now.Let us know how the washers work out since you will be the first to use them. The specs are right so should be fine
