going back to 24v
cucvrus
10,507
Jonestown Pennsylvania
I was being a wise guy. My method is to keep it the way it was designed. It seems to work well near perfect in my opinion and over 20 years of private ownership. So I was offering you to have one of my running CUCV's to copy everything off of. That way you see first hand how it was supposed to be and still should be to get the best results and make the TM's any use at all to you.
bmorrow
Ooltewah TN
That's what I need lol. I am going back to 24. But my pass alternator isn't charging bc every time I hook up the isolated ground it arcs. That's my problem right now.
bmorrow
Ooltewah TN
So I made some major ground on the CUCV today. I got an idea that I should get the relays. I found the generator 2 relay was bad. It was kind of by chance. I just pulled it and put a new in and hooked the isolated ground wire to the hot block and it worked! no arcing. Just thought I would share what the solution was. The only problem I have left is the front battery is not really charging. The rear battery is at 14.5v at idle and the front is at 12.25v. Any testing I can do to make sure I have voltage where I am supposed to get? Should I have 14v on both batteries
Warthog
248
OKC, OK
You should have ~14.5v on each alternator when running.
Check the very top fuse (heater fuse) on the fuse block. It controls the excitor circuit for GEN1.
also remove and clean the 2pin connector at the alternator. Have you checked the voltages at that connector with the key off and the key on?
bmorrow
Ooltewah TN
key on (engine on)
brown-12.25
red-12.05
key off-
brown - 0
red-12.4
new heater fuse as well
new exciter plug
also brand new alternator but there is a chance its bad. with all this electrical stuff it may be fried
also my volt meter never gets in the green. stays in the yellow
Keith_J
1,328
Schertz TX
There are two relays. One for back battery alternator sense, the other for voltmeter. That the VM reads might mean the other relay isn't working.
