going to bob my deuce
197thhhc
15
Williamsburg, OHIO
We put 2 plates on each side bolted through the frames 1/3 of the way back and 2/3 of the way back. Plus there are 8 bolts on each side holding the frames together. I think its a little bit of overkill but I would rather be safe than sorry. The notch isnt as deep as it looks in the picture. The cross members are still together at the top and we use !/8" steel to tie them together on the bottom for added rigidity.
bjsmith
zachary,la
thanks got lil more work done today as of now i have most of the bolts in holding the frames together paln on putting few more then some plates. when i cut frame i didnt cut off enough i forgot to take off for the buperettes also found out that i think the forward sprag is shot it will not go forward without rear dirveshaft but after i put in gear goes nowhere press clutch and can feel it jerk just a little the it works in reverse. anyone know someone selling air shift transfeer case for cheap?
bjsmith
zachary,la
dropped drive shaft off today should have it back tomorrow:-D should have new tubes and u bolts by this weekend. if so i should have it done this weekend and take for a test drive:driver:
bjsmith
zachary,la
Its not real easy doing all the work by yourself with just couple bottle jacks and engine hoist but then again im very impatient and like to get things done
Awesome Possum
Central Texas
I'm getting ready to put the bed on mine and I don't wanna' admit how long it took me! I just wrote that you made it look easy, not that it was! Great Job!
bjsmith
zachary,la
I know I was just looking at you build yesterday good job so far I just wish I had a extra set of hands to help out like you do would have made things alot easier on me
Awesome Possum
Central Texas
Yeah, I did notice you did that thing alone. Outstanding work! Badga (who's 16) did most of the first half due to an injury I have, but I caught up with that pup in putting it back together. When I forget all the problems maybe we'll do one for him!
bjsmith
zachary,la
well pick my drive shaft up this morning then about 10 min after i got home from work ups stopped by and dropped me off mu u bolts and my tubes so got one side of drive shaft bolted up and got tires mounted on the rims and let me tell you that was a job
DeucesWild11
12
Putnam County, NY
Coming along nicely.. Mine bobbed already and hubs flipped when I got her, however with my 395's on stock rims I am about 2" into the frame rails underneath the trailer bed. So the tires were rubbing along those rails under the bed. For now I just cut the rails at a 45 degree angle to give the tires some more room but I think I am going to make the wheel well's 2" wider on the inside to accommodate the larger tires. I don't want to raise the bed any higher than it already is as I need it to be useful. Good luck in your build, she's lookin great!
bjsmith
zachary,la
Glad you said yours rub with flipped hubs I was going to do it this weekend but now im keeping them how they are till I can get new rims
DeucesWild11
12
Putnam County, NY
You may be a little better off than I am. the 14" tires are 14.7" wide compared to the 395's which are 15.4" wide. At least that is what is on paper. However your diameter is 3" larger so you still may have the same problem.aua
