going to bob my deuce
Awesome Possum
Central Texas
Check out this pic that I found on the link below
http://www.steelsoldiers.com/deuce-modification-hot-rodding/51160-how-hub-flip-7.html#post997274
This helped me out allot before I got myself into the potential dirty work..
This picture is exactly what I was wondering about. What are the consequences to the bearings (or any other parts that I'm unaware of) in mounting it with hubs in, wheel dish out? I'm running 11-20R Michelins and will likely continue with these.
bjsmith
zachary,la
if everything goes well i will be finish this weekend and take for small test drive till i get to go to dmv next week and get a tag for it
HanksDeuce
264
Prairieville, LA
Where did you get your driveshaft work done? I was looking at Margot, Inc. in Baton Rouge for mine.
It looks like your driveshaft will hit the trailer frame crossmember. You take a look at that? Might get away with coping an arc out of it instead of total removal.
DeucesWild11
12
Putnam County, NY
Possum, not sure on your question although a good one to ask.. I would assume a little more stress on the bearings if the tire/rim is giving you a wider stance.. but I am not a bearing mechanic or any mechanic by any means. Perhaps ask your question on the How to Hub Flip thread.. There seem to be some very knowledgeable people on that thread.. :beer:
bjsmith
zachary,la
I got it done at mogots cheapest and used them a few times $155 for it to be extended 5" dropped it off around lunch was done the next morning and I plan on notching the 2 trailer frame crossmembers and boxing them in that will be done tomorrow
bjsmith
zachary,la
I think either way will be about the same stress on bearings because the stock dual setup keeps the rim from wanting to twist putting and more pressure on the bearing with the two wheels bolted together it can't try to twist either way unless one of the duals are off the ground
Awesome Possum
Central Texas
Did I mention that I'm running super singles?
bjsmith
zachary,la
got notch finished,welded plates to axle,finished installing driveshaft, got the rear crossmember and bumperettes installed, and got the bed bolted down with 4 bolts so far with few broken drill bits,busted nuckles and a bruise, got the brake lines hooked up now tomorrow ill try to finish bolting bed, cut holes and install glad hands, bleed brakes, and bolt couple plates to deuce frame and trailer frame. also dont know if anyone else had any problems with bed mounts sliding over deuce frame but mine didnt want to sit all the way down had to grind and cut mounts so i could bend them out a little to get them to slide over frame took me half the day fighting to get the bed to slide down and sit flat on frame
HanksDeuce
264
Prairieville, LA
Man you work quick! I hope I have your energy once my lift kit gets here. Wanna help? LOL! Good job on the crossmember notching and boxing! It looks great.
Are you going to add any other supports for the stacked frame besides bolts on the bottom of the deuce frame? I have seen others weld plates to the side of the M105 frame and bolt them to the side of the deuce frame. It gives more strength in the lateral direction from any shear forces exerted on the frame.
The picture below is an example of side support plates, although it's for an airbag setup on a deuce and not a M105 leaf spring suspension. You get the idea.
bjsmith
zachary,la
yes im going to try to get that done tomorrow i will have them right in front of front spring mount and right behind rear mounts also 1 or 2 in the middle on each side so it will be 3 or 4 on each side
DeucesWild11
12
Putnam County, NY
**** bjsmith you do work like an animal... I could perhaps do some more if it wasn't in the 30's here lately.. I love the updates keep them coming and glad I could offer some help, this site has given me so much just glad I could pay it forward.. :razz:
bjsmith
zachary,la
thanks again got almost everything buttoned up didnt connect glad hands yet but brazed copper line shut for now. still have 2 plates to put on from trailer frame to truck frame but did get some on each corner the middle ones are wider that the corners just got tres of drilling. also have a friend coming tomorrow to watch driveshaft while i flex the suspension in the ditch across from my houseaiting to make sure i notched it enough. beside that and some painting its done took it for a ride around my neighborhood, drove good stops better got few looks from neighbors that live in the front now im just waiting for insurance to get back with me then to dmv
