- 10,769
- 7,279
- 113
- Camp Wood/LC, TX
Help us out with the color layers: Looks to be 1960's 24087 (factory) covered with strata blue, covered by white, covered by 1980's MERDC green camo?
I think an AF strata blue tractor would be one beautiful truck! I see a lot of promise in that truck.
I am not sure about the 24087. I saw some primer and then Strata Blue. The final color is a flat military green.Help us out with the color layers: Looks to be 1960's 24087 (factory) covered with strata blue, covered by white, covered by 1980's MERDC green camo?
Thank you for your advice and support. This is going to be a slow restore! I can only do a little bit each day do the the HOT and HUMID weather down here. I also need to keep the expense spread out to keep in budget.With some effort, and sand blasting, that will be one fine ride there. Just take your time and don't rush it. You will be far more pleased with the results if you take the time to do it right.
I think you are going in the rite direction. I know if it were mine, and I could get it to run, AND fix the breaks...... I would drive her around on the dirt roads for a few miles before I made my decision. Seems like once you drive them your whole attitude changes. for better or worse.![]()
i go pick it up today
thanks to tim for letting me use his towbar
well tow it back with my m35a3[/QUOTE
Oh wow, Be careful. I hope your not going far!!
