Gov Planet Refugee
Anvil Motorworks
Castroville TX
Truck is really coming together nicely. I was about to offer you my factory shroud extensions but clearly had no problem fabricating your own. Curious did the LS engine placement allow for you to keep the 4l80 in the same factory position?
sail78385
152
Charleston SC
it’s ok work, doesn’t compare to the stuff you do sir, but I appreciate the compliment.
Factory shroud extensions? I had no idea that’s a thing? Is it an H1 thing or a Humvee? I do believe I should have run the shroud all the way around the fan, but this is what I had here. We will see.
I kept the transmission exactly where it was. Not having to mess with the trans crossmember or the driveshafts is pretty nice.
sail78385
152
Charleston SC
For anyone watching this and taking notes, it’s a whole lot easier to run a returnless fuel system than using the return style I had already. I was able to swap my rails for a returnless style thanks to a local guy here. I could have used what I had but also had concerns about using the factory fuel pressure regulator built into the rails. In conjunction with my Aeromotive pump I just had thoughts about it long term not being the best.
sail78385
152
Charleston SC
New fuel tank showed up, glad that’s done. Ordered some headers and they didn’t fit the best. Ordered another set that I think will be better. Sure I could cut the “ears”’off the transmission but I still don’t like the angle the collector is at.
sail78385
152
Charleston SC
Was traveling for work and came across some Humvee parts for sale. Scooped up a turbo doghouse for $80 and some flappy doors for $150. The Tubro doghouse fits perfect with the LS truck motor. I don’t know what these doors are actually called, but I really wanted a way to access this area when the floor panels are installed. Pretty happy . Just need to clean these parts up a bit and track down the proper mounts for these rubber tie downs.
sail78385
152
Charleston SC
Trying to get the fuel system done as well as the exhaust, so while the fuel tank and soon to be removed muffler are out of the way, I’m using this as an opportunity to go ahead and remove the camber shims. Not terribly difficult, but a few of the bolts are a little hard to reach. I just loosened everything and tapped the mounts with a hammer and they fell right out. I did cut a 3/4 wrench down for this. If I had the time and patience I’d definitely weld some of these bolt lockers on the mounts, I had no desire to unbolt the control arm to do that.
sail78385
152
Charleston SC
Driver side is done, glad all that is behind me now. Is it interesting that there were more shims on the passenger side than the driver? Everything is more square now, but toe needs to be adjusted.
driver side one shim, passenger side 3.
sail78385
152
Charleston SC
Really loving how this wiring is going. My plan is to have the dash look like a regular Humvee, with the ignition switch being used and analog style gauges. The ignition switch has 3 leads coming off it, battery power, accessories, and momentary for the starter. I plan on run the accessory lead into a small fuse panel. This will give me the ability to wire up a few things neatly rather than trying to tap into one wire. We’ll see how it comes out.
Got all my wire from Wire Barn. All USA GXL stuff so it’s good!
just need to plumb the fuel system, a little wiring, and I should be able to see if it runs!
using push lock fittings for the fuel system, not a fan of the braided fuel hose, so this should work perfectly.
monkeyz47
Wisconsin
I am using all of the original HMMWV gauges in my 12V Terminator X LS swap. (in addition to a digital dash to monitor/log more details and have GPS). The problem I ran into was the 12V-24V converter I used for power to the gauges bit the dust, so I have to find a better DC step up converter.
sail78385
152
Charleston SC
The analog style gauges Holley sells are a little pricy but they all daisy chain together and tap into the Holley harness. Should be pretty clean when it’s done. I didn’t see the point in trying to reuse any of that stuff, but it would be cool!
monkeyz47
Wisconsin
Yes the Holley gauges definitely make for a cleaner install (and look better). I had to use 2 coolant temp and oil pressure sensors to get it working. Are you using the Holley GPS Speedometer?
sail78385
152
Charleston SC
So out of the 2 sets of V band headers I bought, none of them came with all of the advertised parts. On both sets the V band Flanges were missing, I was offered a credit of $50 for the missing parts, but was not offered the ability to get the proper flanges. Even after buying a set of V bands from the same seller, they didn’t even mate to the ones on the manifolds. So my only option was to either buy another set and hope they come with all the parts or cut off the flanges and weld on a new set…. So I cut off the old ones and installed new. Now I can start planning the exhaust. Came out ok, probably could have done a better job if I wasn’t babysitting 2 wilds kids
Anvil Motorworks
Castroville TX
Dude! Yes! Is this a known issue?
Had something very similar happen to me with their LT shorty headers. Bought a spare set of vband flanges to so I could have the exhaust turn down immediately but the flanges didn’t match to what was on the header. Pretty lame that the header doesn’t use the newer stepped flanges.
sail78385
152
Charleston SC
Really thought I’d have this thing running and driving by now, but life happens. Got to spend a little time today mounting the ECU and fuse box for the accessories. In error I mounted the ecu too far back that it had interference with the brake pedal assembly. I believe I will cut a 1/8” plate to cover this area and clean it up a bit. I had planned on using a different style mount for the ECU that had the look of rivets, but I ended up having to use Allen key bolts from the other direction so these didn’t work out.
I figure a metal place across where the ecu lives is probably a better idea anyways.
ECU is under the dash, easy to glance at to check on the LED status indicators if needed.
IMG_6793.jpegIMG_6794.jpegIMG_6795.jpegIMG_6796.jpegIMG_6784.jpegIMG_6785.jpegIMG_6789.jpegIMG_6786.jpeg
