Gov Planet Refugee
sail78385
200
Charleston SC
While I absolutely love the look of a 2 door and troop seats it seems that a 4 man setup would be a lot more comfortable, so it’s time to strip it down. I’m also thinking of putting in a middle bench seat -that would make keeping the kids seated a little easier. Got some cool things planned for this phase.
IMG_8088.jpegIMG_8089.jpegIMG_8092.jpegIMG_8094.jpegIMG_8096.jpegIMG_8098.jpegIMG_8102.jpegIMG_8105.jpeg
sail78385
200
Charleston SC
Got the truck outside waiting on parts to arrive, should be pretty cool, I’m pretty excited. I still have to go pick up a windshield frame from a buddy of mine which might hold me up… Anyways, I started to add more seats to the truck. That blue seat in the back I actually found on the side of the road about 2 years ago. I saved it and was going to use it in a deer stand but never did. Was a little shocked how much people want for high back seats, so glad I at least got one for free… stay tuned!
sail78385
200
Charleston SC
Still got some parts I’ve gotta get and some more to install but check this out! FYI I’m not done with the install yet, lots of little trim pieces to add, I just wanted to share some progress photos. The top and doors are made by a company out west called Pipe Dream Off-road. Bunch of really cool dudes making some very cool stuff for Humvee’s. The top is modular and you can pick if you want just the subframe, a fixed hardtop or a removable top. There are options for the back also, like a removable rear window or a fixed window. I only bought the subframe and will be adding the fixed top later on. the craftsmanship that is in these parts is over the top.
IMG_8220.jpegIMG_8223.jpegIMG_8228.jpegIMG_8229.jpegIMG_8231.jpegIMG_8232.jpegIMG_8239.jpegIMG_8245.jpegIMG_8246.jpeg
20,797
View attachment 953832View attachment 953834View attachment 953835View attachment 953836View attachment 953837View attachment 953838View attachment 953839View attachment 953840View attachment 953841
Looks pretty sharp! Guessing down in Charleston you get a few weeks of cold - but nothing that you can't drive through...
sail78385
200
Charleston SC
So I’m not sure if the front hood 2.5” body lift mounts are for an H1 brush guard or not. Couldn’t stand looking at those holes and also don’t find many of the brush guards appealing. So for $20 I got some rubber and made a push bumper. I’d still like to find a way to hide the lower portion of the radiator. Not sure how I’ll do that just yet.
sail78385
200
Charleston SC
A few weeks ago I was working under the Humvee and kept smelling fuel. Aside from needed a fuel tank vent hose I realized I forgot to install the rubber o ring gaskets on the fuel pump mount. The original ones were still on but they were paper thin. I don’t think this is why I was smelling fuel, but the last I want is my first time filling the tank up on this to result in a fuel leak. I took a moment to put some sealant on the brass fuel tank vent fittings too. Last thing I did was order custom fuel lines that are pressure tested. I ran into some issues with the fuel line push lock fittings not sealing well, so it just seemed smart to get some quality fuel lines made.
sail78385
200
Charleston SC
Pretty much got the fuel system dialed in now. I decided I would route the fuel lines through the fuel tank body lift block, this worked really well. Also, I had an odd issue with the taillights I needed to troubleshoot. For some reason I couldn't get the hazard lights to work in the rear, I was using a Hopkins signal converter to feed the brake signal into the turn signals and it worked great, but for some reason it just wouldn't allow rear hazards. I decided to try and use a pair of diodes and it worked perfectly. I hid all the wiring behind a second cover.
