GRC-193 Cable Needed
mutt1966
13
Allentown, PA
Iam hoping that someone can help me out, Iam in search of the Inter-Connecting cable that goes from the Amplifier AM-6545A to the Coupler CU-2064 it would have a NSN # of 80063-A3210317-1, or a Part# of 755017B0791 and it is 5 ft. 0in. long, I have one but the U & V pins are broken off which leads me to this question, on the pin-out it tells me that U is not connected but the V pin on the AMP side of the connector is the G pin on the Coupler side and that pin-out tells me that G is not used so does anyone think that I could use it till I find the correct cable... Thanks for any help, Scott
papakb
1,186
San Jose, Ca
If you've got NC's then it shouldn't make any difference whether the pins are there or not..Give it a try and see what happens.
Kurt
mutt1966
13
Allentown, PA
When I connected the 24 Volt lead from the truck, there was a click on the AMP and the PA fault light came on for a second, everything was turned off so that was a concern, we tested it using a dummy load, when it was keyed I didnt hear the RT give the tone like t does on the PRC-104 and after a few seconds the Fault PA light came on and the beeping started, we tested all the functions and they wre all in spec for un-keyed, when it was connected to the AT-1011 it receives fine, so that is all I can say about it at the moment, any ideas where to look would be appreciated.... Thanks, Scott
