- 4,578
- 4,557
- 113
- Brentwood, Calif
I forgot to add....if you have A2 upper control arms, you will have to remove the upper ball joint to remove it, the newer control arm has a round support piece welded in...early version was just an add on that bolted on.
if you are replacing the entire hub, you will need 2 new ball joints...unless you can your old off with no damage to rubber boot....
