Hard Door Recommendation
Hammer
400
Winlock, WA
I suspect “X” was originally used on oem fiberglass doors for reducing flex and inexpensively adding a measure of fiberglass strength. This would still be true of aftermarket fiberglass , or thin gauge metal doors. However, It is my belief that “X” has become more a design element rather than a form of function for sturdily fabricated doors.
Doors such as these (1/2” thick) from Twisted Metalworks are totally inflexible and incredibly strong. That is my primary reason opting for the “X-Delete” and maintaining that thickness across the entire door.
I agree on the strength of full layers. But I do like the X look as well.
  • Like
Reactions: OBX
Mogman
10,530
Papalote, TX
Are they still two layers of 1/4" or a single layer of 1/2"?
OBX
380
Moyock, NC
2 layers of 1/4” completely bonded together. This is stronger than a single piece of 1/2” according to an engineering article I remember reading. Though I can’t recall exactly the publisher.
OBX
380
Moyock, NC
Nothing wrong with preferring either one.
I don’t mean to imply my design preferences are better than anyone else’s. When completed, my Humvee will be different than any I have seen. Some people will like different features than others, but each feature I incorporate will be for a specific reason having purpose and value to me. Our MVs are very personal to each of us and should reflect our individual tastes and imaginations, to the extent our budgets permit.
Mogman
10,530
Papalote, TX
Yes that is how I was always led to believe, a laminated material is stronger than a single layer.
Autonomy_Lost
1,554
Pennsylvania
I'm not an engineer, but I think that depends on the definition of "strength." I think a laminated material would have more flexibility and less prone to crack. But I don't think the tensile strength or compressive strength would be any higher.
I think another variable is whether the two layers are fully bonded together.
I'm guessing in this case there's probably not much of a functional difference either way.
TOBASH
3,960
Brooklyn, NY
Compression and distraction and toughness are most certainly affected and improved with lamination.
Autonomy_Lost
1,554
Pennsylvania
Perhaps on materials like wood or fiberglass where there is a grain. I'd be interested to see if there is a source proving that to be true for a homogenous material like aluminum.
Edit: toughness sure, but that goes back to my point about flexibility.
Coug
4,794
Olympia/WA
Wood and fiberglass will both absorb the gluing agent into the fibers, effectively becoming one with the fibers. You have a much stronger bond because of this, and the base materials are strengthened with the additional bonding agent absorbed into the fibers.
When gluing two pieces of metal together you only get a surface bond, no penetration. The bonding/gluing agent doesn't soak in at all, and the only hold is the microscopic imperfections in the surface of the metal. It doesn't alter the properties of the base material like it does with the wood or fiberglass.
Lets use glass as an example. If you laminate glass, it doesn't make the glass particularly stronger than identical thickness of glass that doesn't have the lamination in the middle. Glass gets laminated for safety reasons, to control what happens to the glass shards when it gets broken, not to increase it's resistance to damage or change other physical attributes. Also one layer getting broken doesn't necessarily affect any other layers, as that layer breaking absorbs energy lowering the amount of energy going to other layers. Also true in composite armors, multiple layers (often of different materials) laminated together to absorb and dissipate energy, but not necessarily any stronger than if you just made the entire thickness of a single layer of the strongest material in the lamination.
The main advantage I could see to having a laminated metal door is to reduce noise. The glue/bonding agent would absorb a lot more vibrations/rattles than a solid piece would, therefore making it quieter overall. Whether that makes any real difference in practical application though would remain to be seen.
HmmwvTim
102
IL
That door is not closed. It is opened and sitting on loose bolts. Just saying. I didn’t mount anything just a quick dry fit with loose hinges.
i was happy about the c piller. i expected that there would be a big gap at the top of the c piller. It seems to follow the piller nicely It might have been an issue on older trucks though.
I did notice that my rail on my passenger side may be a little low. I noticed it from the bolt points on the windshield a long time ago. I guess until i put hard doors on it, I never knew how slopy they put those rails on. i guess I am going to have to relocate those.
HmmwvTim
102
IL
i do have a question for the seals you recommended. It is rated for 9/64 thickness. Will this sit properly? I found a site that allows for proper fitting but it is 450$ for a 250’ roll. you might want to look into this for future packages to see if it fits better.
Too pricey for me since i only need about a 10th of that.
13
35
13
Nj
Yes i am always looking for better. As i can test different things i will update you guys. I have not had a issue except it does require some time to install without damaging. I welcome input from customers on better things or ideas. Always room for improvements.
HmmwvTim
102
IL
if you buy a role of 250’ can you sell me a 10th of it? How much length is it for all 4 doors?
13
35
13
Nj
Sorry Tim. I am just seeing this. Front doors need around 12ft i believe. Backs about 15 or 16. I am looking at different options. That is the nice thing of using a universal door seal, lots of options.
