Hard door striker for hard doors
revhrd
Las Vegas, NV
Is there a good source to get a complete set that contains the door strikers, shims and backplates? The bolts/nuts are common enough but I have looked a several vendors and no one seems to have the shins and backplates. There also seems to be a lot of the aftermarket strikers and would prefer an own setup.
sgtmike3
Ohio
When we were switching doors on the M998 for the department we could not find any anywhere. We ended up fabricating our own. Good luck with your search. I don't have the plans anymore but can send pics if you want to go that route.
Sent from my Pixel 6 using Tapatalk
Autonomy_Lost
1,462
Pennsylvania
MAC Motors has OEM rear strikers, but no fronts.
I didn't even know about the shims, what are they for? Is it just for making adjustments, or are they always used?
86humv
487
Texas
Shims not required on standard X doors.
Door strykers all over EEEBay
A real set of fronts for 25 pair:
M998 HMMWV HUMVEE NOS 2 EACH X DOOR HARD DOOR STRICKERS 12339385
revhrd
Las Vegas, NV
I guess I'll get some strikers from ebay, and use them as templates for the shim and the backplate since it seems they are the same shape. It looks like the nuts are spot welded onto the backplate. Not a big deal but was hoping to have it all ready.
revhrd
Las Vegas, NV
Just to verify, the NOS ones are not all flat strikers they have that wider part on top, like a bolt, right?
Action
1,552
East Tennessee
Shims are not used front or rear for regular x-doors. The nutplate is only on rears.
Aren’t those drawings for m1114? Look at the long piano door hinge in diagram.
Use the correct diagram / parts list for your application.
Mogman
8,391
Papalote, TX
There are two styles of strikers and as far as I know they are interchangeable, I think the second one is preferred but not sure why, I have both styles on my two M998 and the second style snags my clothing more .
I am not using back plates or shims on ether.
Mogman
8,391
Papalote, TX
I was told by MAC motors the new design (assuming the one with flats on the ends) is to prevent door rattle.
That's hilarious
Edit, it is obvious what they are trying to do is to keep the door latch from moving off of the end of the striker during extreme body flex (as in you wrecked it) to keep the doors from popping open, properly installed nothing is going to be touching the "knob" at the end during normal operation, so it would have no effect on rattles whatsoever.
