Hard downshifting? Really? Or is it you?
MuleMac01
Military vehicle collector
187
Las Vegas Nevada
I can do that i have messed with that b4 I thought i had a issue with the accelertor pedal being very hard to press. it was like doing calf raises in a gym just to drive down the road. Well thank you for giving me a the rpm speed I will look after work tomorrow I will post what i find thanks again
Put some Wd-40 or something better to lube up the wire cable for the foot pedal. It will make the pedal easer to press.
hgun
382
Leechburg, PA
I think the spring that pulls the throttle back to idle is stretched or weak i can move it by hand my rpm's go to 500-550. I repositioned the spring to a diff location it seemed to help, I will have to try to find a new one. I did not get a chance to drive it tonight but i moved it around in the drive way. it didn't seem to lunge. I will take it out over the weekend and see what happens. I did disc the accelerator pedal from the cable to try to lubricate it I can get the bottom pin out with out mangling the end of it. so i sprayed it with PB Blaster and worked it around. the cable that connects to the pedal is still hard to push even by hand with out the pedal connected I will look at that tomorrow and see if i can lube or grease anything there. I will post my new findings thanks for the help guys. I am new to all this but i love the truck so thanks again for your patience
