- 16
- 0
- 0
- Angleton TX
So I bought a used hardtop for my M925A2. It is in OK shape and will require some TLC. My question is....The insulation foam that is on the inside, can I coat that with Rustoleum leak seal or should I strip out the dry rotting foam? My thoughts are if it takes to the leak seal well then it will provide that much more sound and weather insulation. I guess that may equate to just putting lipstick on a pig though. Thoughts please?
