Has Anyone Done A Complete Conversion To 12v?
Tance
Conneaut Lake, Pa
I have a decent low mileage dually (M1028A2) that will soon have a new 454, and I'm thinking about a complete conversion to 12v... using one of the after market wiring kits for an 84 Chevy truck. Good winter project.
I'm not real clear on the CUCV electrical system, so my question is... what about the components themselves (wiper motor, heater motor, dash switches, interior light bulb recepticles, etc). I assume those are all 12v correct?
I guess I'm confused because I hear people saying the light bulbs are special (24v) but someone put a stock Chevy truck steering column in my truck and the wiring connection snapped right in and all the lights work fine.
Any other potential problems you have experienced or would anticipate by rewiring everything to 12v?
Thanks for your replies.
doghead
4 Star General /Moderator
1,193
NY
Take a look at the schematics in the back of the -20 TM. Should be very easy(even using the original engine harness).
shannondeese
19
High Springs Fl
On one of my CUCV Blazers I did the 12 volt conversion in about an hour. The other the harness was shot so I replaced the whole harness with a summit universal chevy harness. It took about 4 days to complete. It's not that difficult a job to do. Have fun with it.
1,827
Only thing 24V is the starter and glow plug circuit and you will not need that. I see no problem with the conversion other than why.
Tance
Conneaut Lake, Pa
Thanks for your replies, sounds like I shouldn't have any electrical surprises. I think I'll get it in the garage and take a close look at the existing wiring. I had an 84 Corvette that the plastic wiring connectors were so brittle they'd break if you tried to disconnect them. If that's the case, I'll go with Shannon's suggestion and try a Summit harness. Don't want any wiring problems down the road, might as well do it right.
