Has anyone gutted a N3135 regulator?
TOBASH
3,483
Brooklyn, NY
My next project. I want to see how to gut and replace innards with working parts. Before I start, I want to see if anyone else has done it.
Mogman
9,569
Papalote, TX
I have not, I have however gutted and repaired several different potted modules in the past. I used Acetone, unfortunately it will also remove some of the component markings, electrolytic capacitors that have a plastic sleeve over them for one thing. Sometimes you can"read" the component as it starts to come out of the potting material, keep good notes.
Usually I would use basic knowledge of the circuit voltages and the physical size of the capacitor to "take a guess" has worked so far.
Keep us posted!!
Mogman
9,569
Papalote, TX
I did just look at one of my regulators, it has a rather "soft" potting material, it could be silicone based, I have no idea how you would go about de-potting something like that.
I too am waiting for an update!
TOBASH
3,483
Brooklyn, NY
Just received a bad 200Amp regulator from Beltfed34 Austin.
Gonna start dissecting it. Trip to Commiefornia to finish work on the M1165 will interrupt.
TOBASH
3,483
Brooklyn, NY
Just started gutting my N3135. Neihoff are such a PITA. They potted the unit in silicone containing 1-2 mm gravel chips. Not gonna stop me.
It’s a cross between the 40 year old toy “chip away” and an archeological dig liberating small dinosaur bones from surrounding rock.
Rear is clean. Just ordered mechanic’s picks to continue the process.
I’m gonna make this happen.
TOBASH
3,483
Brooklyn, NY
All about anti-tampering. What bull crap!
Really offensive to me.
Guyfang
23,990
Burgkunstadt, Germany
Try asking @peapvp as this is something he might be able to shed some light on.
TOBASH
3,483
Brooklyn, NY
Outer is soft… then inner has small pebbles.
Outer is a skim coat to make unit look finished.
Mogman
9,569
Papalote, TX
You are 100% wrong, it all about making it weather and vibration proof, anyone that is serious about "tampering" with it would have no problem getting into it.
TOBASH
3,483
Brooklyn, NY
Mog.., I respectfully disagree. Silicone is anti vibration. Silicone with rocks and powder is another story.
GM, Ford, and Chrysler regulator products don’t have an ounce of silicone and yet they work well, even on bumps. Same with Bosch.
No silicone in G500 Mercedes and no silicone in GM Hummer H1. Our starters and pcb/EESS are sealed and not potted. This could have easily been manufactured in a watertight box with rubber mounting bushings.
peapvp, thanks for the pictures! I’m not finding epoxy in this unit. This is malleable and soft like silicone.
peapvp
1,226
Basehor, KS
@TOBASH
Thanks for the info. The stuff in this particular unit is rock hard. I am certain that is an Epoxy Resin.
We use silicone conformal coating on our circuit boards we manufacture. This here in my example is definitely not silicone based.
Peter
TOBASH
3,483
Brooklyn, NY
So peapvp/Peter, I guess I got lucky with a unit that might be more easily dissected. Seems like there might be differing batches with differing construction.
Glad mine isn’t epoxy.
Thanks for your pictures and your information.
Charles
