- 807
- 74
- 28
- Kennewick, WA
I am getting ready to recover a M109 box from a deuce and a half.
I was going to pull the bed off of a deuce and then drive it 4 hours to the pickup location, load it on the deuce and the drive it 4 hours back.
Instead I am now considering using my 10K lb car hauler trailer and my pick-up truck (2500HD). That will provide a much more comfortable and reliable long distance ride for my 6'8" frame.
From BadMastard's (Jerry) thread the M109 box is only 3800 lbs and the TMs put it at 98" wide. I can't find a box length, but a m35a2 bed fit on the trailer before, so hopefully the box will also. I am figuring it to be a little more than 12' long.
I am going to make up some wide, stable, spacers/blocks to raise the box's frame rails above the trailer's wheel wells.
At the minimum I was going to use 4" wide ratchet straps over the box to the trailer frame, side to side, to secure the load.
How does the box attach to its frame, where it rests on the truck frame?
From the top down are there wood sheets, sitting on side to side 'c' channel beams sitting on top of 2 front to back beams that run parallel to the trucks frame rail, like the under side of a deuce bed?
If so I can use additional chains and binders thru the holes/across the beams of the M109 box and attache them to the trailer.
In the pix is the trailer with my buddy's 401 unimog.
Think it will work?
Any one do this before?
If so how did you make it work?
Got any pix of the underside of a M109 box?
How about its length?
Are there any other points on the box to secure to?
Think it will work?
