gimpyrobb
dumpsterlandingfromorbit!
- 27,787
- 778
- 113
- Cincy Ohio
The lever on the T-case is probably the control linkage for the sprague. You guys remember not all trucks are air shift right?
Got an pics, OP?
Got an pics, OP?
Like I stated in an earlier post, the second plunger that I'm referring to is not for the PTO, the PTO has its own lever that is directly on the PTO that comes out of the drivers side of the PTO.
I agree with gimpyrobb, that its probably to disengage the front sprag. This transfercase is in fact a manual transfercase that does not have air shift...
I still have the non-overdrive 5spd trans, I'll have to verify where the plunger should be in reverse and where it should be in forward gears...
Gimpy is right. The linkage you speak of is to shift the the sprag in the transfer case from forward to reverse when you change gears.The lever on the T-case is probably the control linkage for the sprague. You guys remember not all trucks are air shift right?
Got an pics, OP?
