- 869
- 51
- 28
- Blaine, MN
I say go for it if your equipment is in good shape. There isn't much difference between newer 3/4 tons and 1 tons (srw). The brakes on the trailer are designed to stop the weight of the trailer with the recommened load on it and the truck will stop itself. I have hauled deuces more than 30 times with a Chevy 3/4 ton and a triple axle 21,000 lb gooseneck and it stops no problem. As long as the trailer brakes work good you should have no problems. As far as gvw's go I am under my total, I figure my truck weighs about 7,000, my trailer weighs about 6,000 and the deuce is under 14,000 so 27,000 total. GVW of truck is 9200 and the trailer is 21,000 so 30,200 total CGVW.
