Head Gaskets
M35A2-AZ
410
Tonopah, AZ
I always pull them together and maybe I've been lucky but I have never losened the manifold bolts. Someone told me that's how they do it at Memphis Equipment. Having the correct lifting bar and a gantry makes it all possible.
Jeff
When you use a lifting bar like this for the heads do you need to support the heads in the center of the bar?
Sorry the pic of the bar is in post #11.
gimpyrobb
dumpsterlandingfromorbit!
27,786
766
Cincy Ohio
Also would a Crowfoot wrench work of the head bolts?
Nope, I just pulled some heads yesterday. Infact, I had a box end wrench made up and was worried about the weld breaking. As it turned out, the box end wrench shattered, not the weld.
M35A2-AZ
410
Tonopah, AZ
Well that is not good.
What are you going to use now?
gimpyrobb
27,786
766
Cincy Ohio
The one that broke I found in a parted out truck. I will make another for myself. I thought about using a 6 point(for strength), but there isn't enough room to rotate it, so I will probably use a 12pt again.
M35A2-AZ
410
Tonopah, AZ
Thanks for the info.!!![thumbzup]
