Heated fuel tank project, biodiesel, WVO..
firefox
General
1,844
52
Berkeley CA
Thanks Bjorn,
That was very helpful. I think I will go for a closed loop system and use a combination of electric and possibly exaust to heat the circulation fluid. This way I'll be able to use shore power to warm things up before a trip. I will have to use a variable flow circulation pump to take the high heat factor of the exaust system. Any thermal sensors you can recomend?
If the exaust heat turns out to be very high, I am thinking a mechanical decoupling device might work. Maybe a large bimetalic strip that pushes the contact area away from the exaust tube.
Thanks again for taking the time away from your M757 project to answer my questions.
Bruce
mightymanx
WA
Here is another way to heat the fuel or augment a heat exchanger system
The 24 Volt stock tank heater fits in a 1"NPT hole
I am using these with the 34* thermostat for my black and grey water tanks so I can go play in real cold weather with out having to dump antifreese down the toilet and sink. Nothing is worse than a frozem poop tank on a trip into the boonies!!
Submersible 12 volt water heater cattle water horse heater dog low voltage heater stock tank heater cattle 12 volt water heater Hot Water 48 volt systems, RITCHIE animal water systems, Miraco lilspring animal water systems big sp
The 24volt is on the bottom of the page.
hedgehog69
iowa city, ia
Bjorn, I think you need to wash your biodiesel. I think the bits of methanol and lye are going to be a long term issue.
An alternative to washing is time. Although I have never had my homebrew tested, I always try to let it settle out for a couple of months prior to using it. I also use a small air pump to' bubble wash' it. I have been doing this for 5+ years...and so far, I have had no problems.
I have an old 500 lp tank that I use for a finished tank. I go on a brewing frenzy in the fall and get the tank filled so it can sit all winter. fuel looks beautiful in the spring.
cranetruck
94
Meadows of Dan, Virginia
One potential problem with the electric heater is that it can not be permitted to stay on when the fuel level drops below it, it will burn itself up.
mightymanx
WA
I would put itn the botom 1-2" of the tank and move the suction up a tad and that would cure that.
