firefox
General
- 1,844
- 51
- 48
- Berkeley CA
Thanks Bjorn,
That was very helpful. I think I will go for a closed loop system and use a combination of electric and possibly exaust to heat the circulation fluid. This way I'll be able to use shore power to warm things up before a trip. I will have to use a variable flow circulation pump to take the high heat factor of the exaust system. Any thermal sensors you can recomend?
If the exaust heat turns out to be very high, I am thinking a mechanical decoupling device might work. Maybe a large bimetalic strip that pushes the contact area away from the exaust tube.
Thanks again for taking the time away from your M757 project to answer my questions.
Bruce
Bruce
