Heater Blower Motor Resistor Repair and Replace
74M35A2
341
Livonia, MI
You could just source the low speed side from 12V and eliminate the failure prone resistor. If you are going to reinstall a resistor, I would use one of a higher wattage rating than what was specified. These burn-outs seem to be more prevalent than expected. Be sure the confirm the amp draw of your blower motor to confirm system integrity regardless.
Wildchild467
59
Milford / Michigan
That is what I did. I just got power from my dedicated 12 volt system (separate batteries and alternator for my 12 volt system). I don't have to worry about draining one battery with that system. I still would rather have a 100 watt resistor instead of getting power from my 12 volt system, but it works and I don't have to worry about a resistor going bad.
