- 2,054
- 59
- 48
- Milford / Michigan
The heater blower motor resistor burned out a little while back in my Deuce. I researched a replacement but did not find anybody that had one. Since wire wound resistors are not usually expensive, I decided to see if Newark had a similar resistor. I found a direct replacement and all I had to do was cut off my old wires on my resistor and solder on my new ones. Attached are pictures of my old resistor and the process I took to solder on the leads from my old resistor. There is also a picture to show why my old resistor failed. There was a chip in it and the wires in the resistor rusted out. The Newark part number is MC14662. The values for the resistor are 5 Ohms and 50 watts. I think this is the same resistor the 800 and 900 series, but I am not sure.
Here is the link to Newark.
http://www.newark.com/multicomp/mc14662/resistor-wirewound-5-ohm-50w-5/dp/28K6276?ost=MC14662
