- 18,094
- 27,162
- 113
- Burgkunstadt, Germany
You may need to stick a wire into it, if its plugged up. But its not a problem.
Even if that gets wasted, it's better than a full tank (or more if AUX is being used) being wasted when the existing one leaks the first time you run it overnight & it decides to spew. Then you are out the fuel & power. Changing them out is not fun no matter the route you go, but making sure it is done right, you won't even need to worry about it leaking again.Ok so tomorrow I'm going to try taking it apart and doing the fuel lines. Any pointers for them? How do I get them all off? And anything I should do in addition? I have the fuel tank nuts but seeing as I just put 3 gallons in I don't want to pull the tank if I don't have toDiesel is expensive! I will figure it out but thought I should ask!
Better to drain the tank now when you have time and control, than later when you might not. I would suggest that as this generator is new to you, while you are changing the tank nuts, check for debris, slime, and crud in the tank, and wipe the inside clean. No sense in washing crud into your filters or worse.Ok so tomorrow I'm going to try taking it apart and doing the fuel lines. Any pointers for them? How do I get them all off? And anything I should do in addition? I have the fuel tank nuts but seeing as I just put 3 gallons in I don't want to pull the tank if I don't have toDiesel is expensive! I will figure it out but thought I should ask!
Pull, yank, cut. Doesn't matter. They're designed to bond after some head cycles to seal well. It's why those plastic tees are a throw away item in my opinion.So I got it disassembled it except the fuel lines. They scare me a little. @CallMeColt do I need a heat gun or do I just pull the tubes off and on? The petcock worked great. The bolts to get the muffler off were a PITA though!
None are needed with the OEM line as it is return line, not feed line. It will "bond" after a heat cycle or two & seal up. For piece of mind, a zip tie will do but again, not needed. It's why they're hard to pull off after they have been on. If you are using something else, get something that is the right OD for that fuel line, just don't over tighten. These don't get more than 10ish psi.What size hose clamps do you use? I am having trouble finding 1/8inch.
