Hello - new MEP-803a owner here
pstansel74
Tolland, CT
Success! The breaker was flipped, I reset it and it worked no problem. I am waiting on the parts to load it up should have them by Tuesday. Really excited to see it fully run.
I got a replacement exhaust cover from LitD last week and am having a little trouble figuring out how it goes. See the pics, but could the bracket be bent or something?
pstansel74
Tolland, CT
I cranked it and ran for 30 min or so with about 50% power. I need to get an additional heater to crank to full and benchmark for at least 4 hours. I am noticing some peculiarities with the unit... Things like every once in a while it won't make any effort to crank. I turn it all the way off and back on and it fires right up. I also had it die one time with a no fuel light when 1/4 of the tank was full. So I have to dig into those. I also need to get it to it's permanent home and wired in fully.
Oh and I bent the cover back down ;)
CallMeColt
1,721
Wilson County, Texas
Sounds like a dirty contact somewhere with the starting issue, or sticky relay.
The double float switch may be bad or out of place, causing the false low fuel shut down if you indeed have 1/4 tank.
Guyfang
27,074
Burgkunstadt, Germany
Take a picture of the S1, the back side, in the control cube. lets see what you have for an S1. This often, when it started to go bad, showed this failure. There are three types.
If you continue to have the low fuel problem, say something. There are more that a few reasons this can happen.
Guyfang
27,074
That's the Mark 2 version. Better than the Mark 1, but still prone to failing. I can not say for sure its bad. But its the kind of failure that the first two versions displayed. Did you wiggle all the wires? Check that the wires are tight in the S1? The next time it happens, hold the S1 in the start position, open the control cube and move the wires/switch. See what happens. The Mark 3 switch is nuke proof.
pstansel74
Tolland, CT
Ok... I feel like an idiot but I don't know what to do :) I got a replacement switch for S1. I wired it EXACTLY the same as the old switch and.... nothing. Not a sound to be heard. I checked the crank switch and it still fired off. I rewired and still nothing.I checked the wires accordibg to the wires to components for S1 and they were right. So I thought maybe it was a bad switch. Went to wire the old S1 in and... you guessed it, nothing. I am completely baffled now :( Any thoughts on where to look?
20,738
Have you downloaded the TM's so you can verify the wiring? I mean if you replaced the part and nothing changed - maybe you need to follow the wires as detailed in the drawings?
