Help - stuck sides on a m105
scottjhl
Loxahatchee, FL
Hey guys the cargo sides on my trailer are really stuck in there... pulling and my brother using a hammer with a screwdriver on the outer sides... did nothing...
ANY help with this is appreciated, as I am debating using a hi lift to get them out, but I fear that doing so will bend the aluminum..
-Scott
1,827
Bring it here and we can use the crane as well. No worries about the aluminum, there is none! I normally use a porta power but I see the high lift working too. Oh, get a stronger brother too!
silverstate55
Unemployable
2,130
1,090
UT
The ONLY way to remove stubborn rails.......
SHOWOFF :drool:
I do what Maddawg suggests: I use a big prybar with a block of wood under it to pry them up & out. Worked every time.
Of course if I had a crane or knuckleboom I'd use it in a heartbeat. Every chance I got.
SteveKuhn
Hasbrouck Heights NJ
Had the same problem. Used a HiLift with a wrinkle: Put a 2 x 4 or the like to spread the force along the rack and use some type of angle iron attached to the wood as a lip to get under the wood slats & avoid dinging them. Soaking in PB a day or 2 wouldn't hurt along with some good banging with a BFH and a block.
Not as much fun as the crane but hey, we can't all have great toys.
Steve
KsM715
142
St George Ks
Try the prybar and wood again. Start at one end and pry a little bit right next to the stake pocket. then move to the next pocket and so on up and down the side at each stake pocket. You can not lift to high on one end at a time or it will put the far end in a bind.
scottjhl
Loxahatchee, FL
Yep... tried this... It worked on my brother's trailer, but not on mine.
Has been soaking for a few days now, might try it again before driving over to Kenny's.
Worst case, another drive of the truck... darn ;)
