Help : what is missing?
fpchief
229
South Alabama
We just got an 1123 in and it was missing the CDR valve also. I was wondering about why until this thread popped up. Makes sense now.
They ripped the fording switch out ...which was nice.
Looks like they hammered it trying to destroy the valve while still installed....
fpchief
229
South Alabama
Ya I think it is. I went ahead and got a ful DWF kit because so much is gone, the switch, the intake stack, the exhaust, etc
Probably was a good idea. You most likely will not have to take off breather, I doubt they messed with the kit that goes on the bottom of it.
tgejesse
289
Maryland
Let me guess, M1123 from Barstow? I just noticed this exact same thing on my hmmwv. They shoved a
‘gap’ hose from one hose to the other. They destroyed one of the hoses when doing this. I just ordered a CDR (not the fording one) and two new hoses.
I’m curious if this will effect blow by in any way. Did anyone here experience a reduced blow by when adding / fixing / replacing the CDR?
Crik13
Virginia
I have the 1123 also, missing the cdr and switch. Mine will not shift up or down, checked for vacuum leak by spraying starter fluid on lines, no change in idle, fluid is clean and full, any help is greatly appreciated?!
Crik13
Virginia
I haven't noticed any change, I have also taken the air cleaner components out and put a small open k&n filter in its place.
diesel_dave
286
Utah
This is a diesel engine so there really isn't any vacuum. None of those tubes have anything to do with the transmission shifting issue you are having.
diesel_dave
286
Utah
Thank you,, Any idea of what it would be?
You have a 4L80e where the "e" stands for electronic. Which means the transmission is electronically controlled. That being said, there are about a dozen basic things that could cause what you describe. Is your truck stuck in first gear or is it in second? If it's in second, it's probably in limp mode.
Crik13
Virginia
Seems like over drive, take off is a little sluggish then gets upto speed and when I let off the gas and apply gas again it revs up to catch up where it left off.
Mogman
10,494
Papalote, TX
ALSO for you guys with no CDR valve, that hose in the middle of the bracket goes DIRECTLY into the intake, one small screw, washer etc. and your engine is TOAST, do not pass go do not collect $200 it's time for a new engine!!!!!!
PLUG THAT HOLE!!!!!!
blutow
501
Austin, TX
It sounds like it's in limp mode (which means fixed in 2nd gear). This document (link below) has some really good info about how the transmission works and how to troubleshoot it. I'd start by checking the breaker behind the passenger seat. The transmissions is all electronic and the brain is in the box behind the drivers seat. Lack of electical power can cause limp mode (check breaker) or it could be any number of other faults. I'd also check the connection to the transmission box and transmission. Disconnect the negative on the main battery before disconnecting or reconnecting the TCM harness.
Mogman
10,494
Papalote, TX
Actually the 4L is not all electronic, it is a half breed/messed over regurgitated TH400,,the 6L was GM's first all electronic transmission
