tcruwithme
- 16
- 18
- Eagan, MN
In the summer of 2014, I relocated my coolant cab heater into the cab under the map compartment in my A2 like they have them in the A3 trucks. Here are a couple of pictures of what that looks like: Picture #2 is where the lines come into the cab, from inside the cab. Picture #2 is where the lines go into the cab, from the engine side.
![20140905_101157[1].jpg 20140905_101157[1].jpg](https://www.steelsoldiers.com/data/attachments/350/350864-7e5d6902af98e935728f17fb035c5321.jpg)
Later that same summer, I installed a Cummins Fleetguard heavy-duty coolant filter housing, bracket, and filter above the passenger side headlight. I have the coolant coming out of the top of the block and going into the coolant filter. It comes out of the coolant filter and goes back to the heater in the cab. It then returns to the bottom of the block. I've driven the truck a few times for a couple hours at a time, and the silicon heater hoses are doing fine where there are. Here are a couple of pictures of what that looks like:
![20150321_160410[1].jpg 20150321_160410[1].jpg](https://www.steelsoldiers.com/data/attachments/374/374497-c9afb15d11e85a30f1436173521cb6eb.jpg)
I didn't drive my truck during the winter of 2015-2015, but I have driven it a couple times this December. I noticed that even when the truck warms up, the heater doesn't heat. The fan works fine (both high and low), but there is no heat output. My first thought is to bypass the coolant filter next weekend and take the truck for a drive. I wonder if the coolant filter introduces too much resistance against the flow of coolant fluid. Here's where I could use your experience and opinions.
I think I am using the correct ports on the block for the heater, but if you can confirm, that would be great.
If I can't put a coolant filter in series with the cab heater, where else can I plum the coolant heater into the system?
I'm not sure if I even know the right questions to ask here, so any thoughts you would like to share are greatly appreciated.
Thanks for your help.
![20140905_165417[1].jpg 20140905_165417[1].jpg](https://www.steelsoldiers.com/data/attachments/350/350879-2e9aab2f34afb28cf32e737dc60bc50c.jpg)
![20140905_101135[1].jpg 20140905_101135[1].jpg](https://www.steelsoldiers.com/data/attachments/350/350860-4adbf848053cb0cd7c552c8728dcc222.jpg)
![20150321_160344[1].jpg 20150321_160344[1].jpg](https://www.steelsoldiers.com/data/attachments/374/374494-d0d06b3fcb8adbad111d263553e9e985.jpg)
