Help with Rough Country 4 inch lift
scottodog
nj
I got a 4 inch lift with front springs and rear blocks but the u-bolts are for a 3/4 ton and won't fit the dana 60 and corp 14. Can someone tell me what ones i need and where to get the u-bolts? Thanks Scott
scottodog
nj
Front and rear are wrong. It looks like superlift front kit might be 3418 just need a number for the rear u-bolts for a 4 inch block.
Cucvnut
61
Carver, Oregon
did you tell the company you got your lift from you had a K30 ? also do a u bolt flip in the back so the rear u bolts have the nut on top of the axle instead of under it so they wont get caught on anything you just need u bolts plates from DIY4x4
My lift is from rough country to. The dont make U Bolts for the Dana 60's you will have to get them from superlift. They told me that when I bought it from them...fortunately I have a Blazer, so what came with my kit was good to go. I still have not had a chance to put it on though.
AJMBLAZER
Paducah, KY
Try your local parts stores and see if they have what you need. NAPA has scads of applications but for the Dana 60 you're probably SOL. I ended up having a local parts store make me a set of U-bolts. The two studs on the passenger side I just replaced with longer Grade 8 bolts. Worked fine.
